belstein with swift vs. kyb with swift
Old Jun 23, 2011 | 11:52 PM
evilempire76's Avatar
I recently went from stock struts and springs to a set of MR Bilsteins with Swift Sport springs. The Bilstein / Swift combo is more comfortable than stock struts / springs combo.
I was a skeptic as well, but I couldn't believe how much better the ride is with the Bilsteins. I'm very picky about ride quality. You won't be disappointed with the Bilstein / Swift combo.
Here is a link to my thread with some pics of my car before and after the Bilstein / Swift install.
https://www.evolutionm.net/forums/ev...past-year.html
Old Jun 24, 2011 | 05:46 AM
Smike's Avatar
^ like others have said above. The Bilsteins ride smoother and are more comfortable. KYBs are stiffer, might be better on smooth tracks. But will beat you up a little more on the streets. Where the Bilsteins smooth out the road imperfections.
Old Jun 24, 2011 | 05:53 AM
krazykorean84's Avatar
I don't mean to lead the topic in a different direction but which on is better in terms of handling, Bilsteins or KYB? Or are they equivalent?
Old Jun 24, 2011 | 07:54 AM
n2oiroc's Avatar
It depends. Id say the kybs on smooh surfaces and the bilsteins on bumpy surfaces. Not enough difference to matter though.
Old Jun 24, 2011 | 08:07 AM
Iowa999's Avatar
As to why: the KYBs have more low-speed compression, so, as long as you don't hit a bump, the faster weight transfer makes for better handling; the Bilsteins, in contrast, are much more digressive in bump, so they ride much better on bumpy roads.
Connecting the dots: revalved Bilsteins (to have more low-speed compression) are the best of both worlds.
Old Jun 24, 2011 | 12:00 PM
Neal@tirerack's Avatar
+1 on the Bilsteins. Better match to those springs.
Old Jun 24, 2011 | 03:28 PM
umopp's Avatar
Originally Posted by erald01
thanks for the offer but lets just say i am getting the belsteins fro 1/3 of your price , with around 30k miles on them....thanks for the input though. I want the comfort on the car as i daily drive it in summer, but hate the look of how high my front end is. I am leaning pretty hard towards the bilstein/swift combo though.
I highly doubt you're getting the Bilstein HDs for that low, you're most likely getting the MR Bilsteins.
Old Jun 24, 2011 | 03:37 PM
Evolicious8's Avatar
I read SMIKE's review on this...
So is there a major difference in ride quality between the MR and HD bilsteins?
Old Jun 24, 2011 | 07:57 PM
n2oiroc's Avatar
no, assuming they are both mechanically sound, they are very, very close.
Old Jun 24, 2011 | 08:04 PM
4G63kevin's Avatar
Bilsteins are smoother than the Kybs. I have Swift Spec R's on my Bilsteins and they're awesome.
Old Jun 24, 2011 | 08:41 PM
Smike's Avatar
this
Old Jun 24, 2011 | 08:49 PM
erald01's Avatar
just got them from my buddy for a REAL good price, a little rusty on one of them but that what happens when you drive in the north. Gona sand them a little then spray them with rust protection, will order the swift spec r's this monday. Can not wait to ride low and comfy, getting sick of KYBs
Old Jun 24, 2011 | 09:09 PM
Iowa999's Avatar
Because the difference is in the low-speed damping, probably not.
Old Jun 26, 2011 | 02:34 PM
Fknfstevo's Avatar
I have the swift spec r on kybs, the springs are an awesome upgrade as far as handling goes but for ride quality, not that great. Cruising around town is very rough, bumpstops. Yall that have the swifts with the HDs are yall hitting the bumpstops? Or have already installed aftermarket additions to correct it?
Old Jun 26, 2011 | 03:41 PM
n2oiroc's Avatar
Mine rode ok at first on the kyb's but the back started sagging and bottoming more often, the rears were just wore out. Swapped bilstein hd's and it was night and day better. Save up, they really are a massive difference.
Quick Reply: belstein with swift vs. kyb with swift
