Can a Stock EVO run R compound tires?
Yes, you can run R compound tires, but
I would really start tracking the car on street tires until you have about 10 or more track school days under your belt.
I would recommend a more aggressive alignment for the track.
Stock pads are good for the most part.
Most R compound tires are meant to be shaved. However, Ive read about so local auto xers running the Proxe RA1. I think Shiv runs em too. They look like some good rubber. I may pick a set up for the summer time.
For an alignment, get -2 camber up front and -1 to -2 camber in rear. Tire wear wont be bad at all, and grip under hard cornering will be excellent.
Probably so if you're autoxing. But I really think if you're tracking the car the combo of stock pads and some R compounds will melt those stock pads.
vortico
Aug 30, 2011 06:09 PM
machron1
Aug 20, 2005 06:22 PM
