which R comp
My car isn't too low. My spring rates are 11k front 12k rear. The reason I would like to switch to an R comp is my nt05s don't hold the power. Although it is fun to slide around it would be nice to have traction when I need it. So it sounds like my camber is good. I just need to roll my fenders and pull the liners.
I have a set of pilot sport cups that came off a 2010 GT3 for cheap. 3300 street miles. 3mm in the rear 4mm in the front. They are not down to the wear bars yet. Sorry to thread jack lol.
As long as you arent going to be doing much or any road driving on the race rubber your camber is perfect , I run a little less 2.2 in the front but i have an RS, no ABS and it helps with the braking a fair amount and i keep the pressure in the mid 30s .
Good luck with your setup share pics when you get it together.
One note on the fender liners - they are soft plastic. They will "self clearance" even if you do initially get a little bit of rubbing. The only place to be concerned is in the front where the metal supports are on the back side of the fender liners. if you rub though to the metal - well, metal trumps rubber and will wear your tires a bit. . .
As others have said, if you are just starting out with AX and track days I would try to run a street tire class if your local SCCA chapter has one. That way you can have one set of tires that does it all. . . and my recommendation for that would be the Advan Neova AD08, Hankook, or Dunlop Star Spec.
MisUnderStood
Jul 21, 2013 01:12 PM
Dosagex
Jan 27, 2010 07:08 AM
