STU wheel recommendation
Old Jul 8, 2011, 04:23 PM
SonicEvo's Avatar
Hey guys currently I am in Street Modified for autox running 255/35/18 Hankook evo V12's and am going to be upgrading to Hankook RS3's but even those can't make me that competitive compared to these guys on r-comps so I have decided to drop down to STU. The requirement for that is a maximum tread width of 245mm and a minimal tread rating of 140. My question is what would be the widest wheel you guys would recommend for that size tire? At the moment I am running 18X9.5 Rota Grids but am also debating 17's. Any input would be appreciated.
Old Jul 8, 2011, 04:26 PM
chu
chu's Avatar
STU rules require running a 17 inch wheel doesn't it, or has that changed? I think wheel width is not limited however. From my experience, everyone I've seen running STU uses 17x9.5.
Old Jul 8, 2011, 04:50 PM
SonicEvo's Avatar
Nothing in the SCCA rulebook says anything about wheel size only wheel width
Old Jul 8, 2011, 04:52 PM
Blitz's Avatar
Isn't 245 max tire width in STU? Wouldn't 17x9.5 be overkill for that?
Old Jul 8, 2011, 05:59 PM
BriK's Avatar
Ditch the heavy, weak Rotas. Go for 17x9's fer sherr. Enkei RPF1 for lightweight at a reasonable price. Weds TC105N for lighter weight, stronger, but slightly more spendy.
Old Jul 8, 2011, 06:09 PM
SonicEvo's Avatar
if I were to go to 17's it would be rpf1's.
Old Jul 9, 2011, 09:28 AM
chu
chu's Avatar
245 on 9.5 isn't that bad. And look on the bright side, not you can also post pics in the STANCED thread becasue you're stretching tires. LOL
Old Jul 9, 2011, 09:44 AM
Iowa999's Avatar
Why a new thread?
https://www.evolutionm.net/forums/mo...heel-size.html
https://www.evolutionm.net/forums/mo...ep-thread.html
Old Jul 9, 2011, 10:18 AM
SonicEvo's Avatar
Not one of those guys said which size wheel would perform best. I saw recommendations from 8"-10".
Old Jul 9, 2011, 01:40 PM
Boltz.'s Avatar
I would run a 17x9.5 rpf1
Old Jul 9, 2011, 03:04 PM
Iowa999's Avatar
Originally Posted by dgoodnstuff
SLICKS all the way!!!
Yeah, man. I, like, totally agree. My only question is, like, why did the thread-starter leave the "PID" off the name of the class that he's planning on, like, competing in?
With that out of the way, +1 on the 17 x 9.5s for 245/40/17s.
Old Jul 9, 2011, 04:31 PM
SonicEvo's Avatar
I just wanted to make sure it wasn't too stretched.
Old Jul 9, 2011, 05:28 PM
Iowa999's Avatar
I hear you and I'd probably get 9s, myself, since you won't gain that much lateral grip running 9.5s, instead, and 9s weigh less and cost less. What tire are you thinking about? Some tires are known to run wide and/or not mind being on the smaller-width rim. I know some national drivers are still on 17x8s with RE-11s, but that seems to be underkill to me. RE-11s would probably reach their max grip on 9s, so they'd be a good example of a tire that is happy on a less-that-max-width wheel. However, I've also heard that the StarSpecs like a wider wheel, so if you're going that route, maybe 17x9.5 is right.
Old Jul 9, 2011, 07:46 PM
SonicEvo's Avatar
I am 100% settled on RS3's. I am just split between just putting a set on my existing Grids which are only $100 more for 18's and in stock or get 17" rpf1's and have to wait for 245/40 RS3's to come back in stock. Since these are only going to be used for events I see no reason to spend the extra cash on Z1's when RS3's have better dry grip.
Old Jul 9, 2011, 08:05 PM
SonicEvo's Avatar
Who has the best deals on rpf1's? If the price is right I will go 9.5". 9" weight 15.2lbs and 9.5" weight 16lbs.
Quick Reply: STU wheel recommendation
