ISC coilovers
Im running them. Ride quality is great . And I find the dampeners to be more accurate then bc coils . I run 20hard in the front 19hard in the back witch is pretty stiff not sure what 32 would feel like and never really want them that stiff lol. I also tried them at 16 and the ride was awesome barely feel bumps . Try them out you won't be disappointed just make sure you get the spring thrust bearing .I love mine .no spring lock sounds
What's useless about it? He asked ride quality and I answered with my opinion as I am using the isc coilovers...Not sure why your even commenting when you yourself are just bashing peoples posts with "useless posts".
To the op if you need pics of them in a Evo let me know.I know there is very little info/pics
Go do some reading probie.
Mark Twain put it best. "It is better to keep your mouth shut and appear stupid than to open it and remove all doubt."
You've opened your mouth enough in this thread already. You might want to start with threads in this forum before you attempt at opening your mouth again.
See the Twain quote above.
You clearly have ZERO idea what you are talking about here. You bolted on something you don't understand.
8k front and 6k rear is a good place to start thinking about what you have done to your car.
Give us some insight then. And spring rates are 1 off from hypermax 2,tein ss and zeal.I use my car for daily drive having 8.0=448 lbs/in 6.0=336 lbs/in
Not a huge difference from 8/7 zeals,and 7/6 hypermax 2.
7.0=392 lbs/in
7.0=392 lbs/in
