20mm Spacers & Handling
I'm thinking about getting some 20mm spacers to make my MR look a little better. Do the spacers or the fact that the wheels are pushed out 20mm affect the handling in any way?
I've run spacers on my car for 3 years and tracked my car with 25mm spacers. No ill effects.
What you need to know is that by putting a 20mm spacer on your front wheels it changes your scrub radius. It will cause the car to torque steer a bit on throttle and it will cause the car to be a bit more unstable under braking.
I've done it and I do it. Its fine, but know that this is a certain... expected reaction.
If you removed spacers prior to doing an auto-x or track day would a realignment need to be done? I like the idea of 15mm spacers on my car for aesthetics and would think it would be easy enough "if" an alignment wouldn't need to be done every time.
Those style spacers make me nervous. Anybody have any experience with such spacers? The extra rotational mass is a negative. I assume if you properly clean the mating surfaces and properly torque the spacers to the hubs you should be fine. I wonder how precision designed they are, balance issues?
