Cutting Fender Liner
I run 3.25 to clear the fenders You may want to conceder adding more camber and that should fix your problem. Plus it doesn't hurt to have more on our set up. Just make sure when adding more camber that you adjust the camber plates and not with the bolt at the bottom because you may not clear the suspension on the inside of the tire.
I don't know anyone that has been able to successfully roll there front fenders. I don't think it's even possible.
I ended up using a heat gun then using a rubber mallet (rubber side) to push the liner back. Placed a piece of wood between the fender and liner to get both sides half way equal. Just don't use much heat, I accidentally pushed the rubber mallet through the liner so had to cut a square piece out of mine.
