BR is conducting a suspension test and looking for input
#49
Alright you suspension guru's. Only answer this if you are 100% sure of the answer.
Going to a race tire on the EVO requires a heavier spring. Let me use two examples:
A6, 255 or under, car and driver 3000-3300 pounds, what front/rear spring and camber does it need?
A6, 265+, car and driver 3000 or under, what front rear/spring and camber does it need?
Yeah, I know there are variables, just give me a ball park, from the guys in the know.
A capable driver could run 10k / 12k and be great with a 140 street tire or a 285 Hoosier. That's a great starting number btw and what I recommend people all the time. If you're worried about DD ride quality step down to 8k/10k or 9k/10k.
If you're doing heavy aero, that's really where you should start looking to buck up your rates imo. My .02
#50
^^I'm close to Boom's comment as far as setup.
Old Paul Gerrard spec Ohlins, 10k front, 12k rear. Whiteline RCA and ES bushings. 17x9.5 wheels with 255.40 140 rated tires. The car handles way better than my handling capabilites allow, but everyone who's driven likes it.
One reason why I like my Ohlins is the serviceability. That alone makes it worth the price up front for them. I plan to get mine rebuilt this winter, and PSI are going to make them brand spanking new again, with whatever spec I want. Thats not something easily attainable with those "cheapy" brands.
#54
WHAT SUSPENSION IS CURRENTLY ON YOUR EVO?
kw variant3 650lbs front 600 rear
WHAT PRICE DID YOU PAY FOR YOUR SUSPENSION?
~$2400 new about 3 years ago
IF YOU HAVEN'T BOUGHT A SUSPENSION YET WHAT PRICE RANGE ARE YOU LOOKING AT? 0-$500. $500-$1000. $1000-$2000. $2000+.
Looking at a high end double or triple adjustable setup with remote reservoirs, either Mouton, JST, or AST
ARE YOU GOING TO RUN THE STANDARD SPRINGS RATES THAT COME ON THE COIL OVERS YOU INTEND TO BUY OR SOMETHING CUSTOM?
definitely custom spring rates. Moutons are nice because they offer your a spring "package" with multiple rates for tuning.
IF YOU ARE GOING TO RUN A CUSTOM SPRING RATE WILL YOU BE PAYING TO HAVE THE COIL OVERS RE-VALVED?
custom valving will be required
WHAT ALIGNMENT SETTINGS DO YOU RUN/PLAN TO RUN AND DOES IT CHANGE FROM THE TRACK TO THE STREET?
currently running -2.8 camber front, 0 toe, -1.5 rear 0 toe. This is expected to change for next season.
WHAT SIZE TIRE WILL YOU BEING COMPETING ON?
285/35/18
WHAT TYPE OF TIRE WILL YOU RUN MOSTLY?
1. Street tire tread wear 139 and under.
2. Street tire tread wear 140 or over.
3. DOT race tire, like A6, C51 etc.
4. Full race tire.
DOT race tires. Most likely Kumo's for longevity, but Hoosiers are good for the best performance. Also looking at a new Goodyear tire, but limited availability might affect that choice.
285/35/18
4. Full race tire.
#55
Dave,
FWIW, the 255 A6 is the EXACT same width as a 275 A6. the 255 has a much MUCH shorter sidewall. i found i was getting excessive tire roll over with the 275 even with a lot of pressure. i went to the 255's and with the 1 event i have one them am VERY impressed with them. i went from being in the top 10ish in the raw times to 2nd last event with 99% of the same drivers there.
nothing else changed on the car.
car currently has-
Ohlin coils
whiteline front sway
whiteline bump steer kit
whiteline roll center kit
robi spec rear bar (too big, going to softer bar after i do the diff rebuild)
the car is pretty simple as far as mods go, but does fairly well at autox.
I also plan on rebuilding the coils this winter at psi to run 12k rear. i will leave the 10k fronts alone.
cant wait to see what next year brings!
car currently has-
Ohlin coils
#57
Thank you all for the input. For reference Apexi, which is the "cheap" coil over I run on my car, is rebuilt here in the states at Apexi and the cost is $80 for revalving.
How many of you guys with 10K+ fronts and 12k+ rears drive the car on the streets often and actually can honestly say the ride quality is good?
#59
