Brake Bleed - Stumped!
Your problem is more than likely that there is air trapped in or near the ABS control unit.
Check out my thread- I uses nearly 2 gallons of fluid before figuring this out.
With the system pressurized, crack open all the fittings going in to the ABS unit. It will make a mess and you will lose a lot of fluid, but it is still better than flipping the car over.
Good luck!
Good luck!
https://www.evolutionm.net/forums/ev...-bleeding.html
It is not really an informative thread, I just linked it to show I had a similar problem. It is still not 100%, but I believe with one more bleed it will be as good as it gets.
Good luck!
Good luck!
This is what I thought too.
EvoDan2004
1954
Oct 21, 2019 04:23 PM
Evo Eric
32
Apr 7, 2016 01:35 PM
Foxman92
Jan 10, 2016 06:49 PM
nickolime
Sep 1, 2015 08:19 AM
