is 17x9.5 +12 a good offset??
^^ why would you ever want to run -1 F and -1.5 R ?
i think what chu mean was a stock body evo 8/9 unmolested or modified in any way. pulling quarters, relocating bumper bolts, and shaving fenders is not at all stock and not as easy as a simple roll.
it all depends on what your going for....performance/wide tire (to a certain extent) then mid to high 30s offset. super sick hella jdm tyte wide wheels for looks, go 0 offset and adjust the car to fit the wheels. anythings possible with the will and deep enough pockets.
Rear bumper tabs will have to be removed or heated and bent , best removed so you don't risk cutting your tires, If you're lowered too much that is.
BTW, No need to slam your car. Run the proper rake & make sure there is no rub what-so-ever in the full stroke of the suspension. (Any form of rub is not acceptable=)
WTB[Northeast]: Perrin PSRS Offset Model
Roen
Jun 26, 2016 07:09 AM
Lightsped
Aug 15, 2013 09:30 AM
GTS_666
12
Dec 11, 2007 11:48 AM
