245/40/18 Nitto Neogens?
Hey guys, i am planning on going with 18x9.5 +20 (and a 3 or 5mm spacer all around) i was just wondering about tire sizes. I am lowered on Tein springs and would like to go with the biggest tire i can with no rubbing or fender mods. I am currently on 18x9 +29 with 245 dunlops which seem to run a bit small so i have some room to play with. I believe 245 Nittos will run a bit bigger than the Dunlops though. Any input would be appreciated!
255/35 and they may still rub if you don't plan on running any camber.
when i had my 18x9.5 +22 TE37's i ran a 245/35 and i had no rub issues, granted that's also a rubberband tire, but it gave me hella clearance.
Neogen is a crappy tire anyway I have the same setup except I use 9.5 rim and there's no rubbing on Z1 Star Spec but there's quite a rubbing with 4D (all Dunlops of course).
I am running grids 9.5 +20 with 255/35 nitto's no spacers and rear rolled fenders. -2 camper in rear and -1 in front. I could probably get away with 5mm spacers or 265 tires. Hope this helps.
Thanks for the input guys
Noize
19
Nov 17, 2012 12:01 PM
VT Mitsu
28
Apr 15, 2010 09:18 PM
