Pushing all the way down during brake bleeding bad?
So I did the 2 man method bleeding my brakes and had my bro pump brakes. What I didn't do was tell him not to press all the way down and now i have brakes that are always in contact with the rotors. Essentially I have dragging brakes or over pressurized brake lines. Would steeping down all the way on the brake pedal cause this?
all the way down is sometimes an issue on an old car where a step has worn in in the MBC. If you push all the way through, you can ruin the seal. Not likely an issue on an Evo - not old enough ...
Are all your calipers seized up or just one?
I've only checked the last wheel for wheel spin which is the pass front. It did not spin after I press brakes while wheel was in air. Fronts did register higher at 200F while rears at 140F though that could be front being used more?
I'd say redo the bleeding process. Either pump them till they get firm then bleed it of and keep doing that till no more air, or also i heard people doing is just puck the brake down hold it till you open the bleeder then close it then let off and repeat as necessary.
