help brake line bent
hi guys i was under my car today and noticed the brake line on the passenger side caliper was bent a little, its the one on the bottom of the brembo caliper only a couple inches long. does anyone know where i can buy one or do i have to make it?
http://www.lancershop.com/customer/home.php?cat=97
What about aftermarket brake lines? Maybe they'll fit a stock car.
those lines are to replace the rubber lines that go from the caliper to the wheel well. Your best bet would be to try to get a used caliper that needs rebuilding and rebuild it with that part. I know i've seen some toasted brembos on here from time to time that pretty much need everything done to them, that part should be ok though.
If you feel that the brake caliper is not performing correctly or bleeding your brake fluid is difficult then it would be a prudent choice replace the hard line. The cheapest way would probably be a used caliper.
Do not try to bend it back though because those hard lines have a small inner diameter and by bending even more it might make it worse.
timmycat
Aug 30, 2016 12:58 PM
bakuro117
10
Feb 27, 2013 10:05 AM
SparkTech
26
Dec 9, 2011 09:10 AM
revvin9k
Feb 14, 2010 09:30 AM
bandwagon
15
Apr 11, 2007 10:12 AM
