Your thoughts on new summer tires
I've started researching some Extreme Performance Summer tires (as defined by tirerack.com) which I will potentially use as replacements for my worn Dunlop Direzza Sport Z1 Star Spec.
So far I have the following and would like to hear your opinion and comments or suggestions on tires that I haven't considered:
Yokohama - ADVAN Neova AD08
Hankook - Ventus R-S3
Bridgestone Potenza RE-11
Or just stay with the Star Spec
... we can also consider the
Sumitomo HTR Z III (in the Max Performance category)
and the ever-popular
Yokohama S Drive
Yokohama S Drive
Yokohama S Drive
Yokohama S Drive
yup, not in the same league ... but after some thinking I think I'll continue with the Star Spec (worked well before in both dry and wet, and I dont do enough track days anymore to justify the RE11's)
Well if you're not pushing them to their limits which is pretty crazy on the streets then you don't need them.
anyone use the michelin pilot super sports? They are incredible tires. I had Potenza RE-01R's which were awesome, but kinda loud. Then I tried the Ventus v12's and they were super quiet...but the sidewalls were like mush. I was sliding all over the dry road.
The Michelin Pilot Super Sports are the best of everything. They're quiet, stick like glue to the road, supposedly last a long time. Going from the v12's to the super sports was like night and day.
I'm also looking for tires in a 265/35/18, I do not drive the car in rain - it's only a nice weather car and I don't track the car, although that might change, but I doubt it. I just need a good street tire that can grip on the on-ramps if you guys know what I mean
I had narrowed it down to AD-08, Star Spec, RS-3, RE-11 (In no particular order of preference)
from what I've read you really don't need AD-08 or RE-11 unless you track the car, so I guess it comes down to whether its worth it to have really nice tires if I never see track time, or if the Z1/RS-3 will work. The RS-3 is the cheapest from what I've seen
my vote is the rs3. Put a set on my car end of last season and did a couple auto-x, hill climb, and a track day on them. The grip is amazing! this year i went with a 255 on 9.5" wide rim and will run that for the first few events and see how i can hang with r comp guys but i think it will be close (for my local scene that is)
When all things are considered (performance/cost/wear) i dont think the rs3 can be beat
I've been run off the interstate twice and no problem (well, I got some grass seed in the intercooler). Within days of the second event this also happened to a co-worker in his weeks old Honda. He ended up overturned in the opposite lanes and the car was totaled. So, having a car that handles can be important even in everyday driving.
I have 255 rs3s, my two of my friends have STi's with 255 ad08 and 265 star specs. All 3 cars are DD / weekend track cars. All run similar suspension mods (they run KW v3s and I run ohlins, all run swaybars, similar spring rates and camber, all on stock brembos with dba4000s). Here are my impressions.
RS3 - cheap, very quiet and comfortable for DDing, highest grip, soft sidewall makes it less sharp on the track, gets greasy if you over-work it and then looses traction and slides, WILL wear out fast! They will last 1 year with regular fall/summer/winter driving and 10 track days
ad08 - not so cheap, kinda loud and harsh for DDing, lowest grip, hard sidewall (very nice and sharp turn in), takes a few laps to work them up to get grip...otherwise feels like hockey pucks, I really doubt you will overheat them, will last the longest. My friend put I believe 8 track days on them plus DDing last season all on -3 front camber and they look brand new...
starspec - not cheap, LOUD as hell and harsh for DDing, great grip, great still sidewall with great turn in, always has a lot of grip (hot/cold/street/drag/whatever), most grip (IMO) in the rain too (my friend did a rain trackday and I was there to witness him kicking ***), I doubt it will be easy to overheat, pretty durable in terms of tire wear.
My overall pick is the starspecs if you can stand the noise and harshness. Its the best balance of all categories. Then ad08s. The rs3 is good if you mostly do a lot of tracking, know how to manage tire heat effectively, don't mind the lack of feel, and want something cheap. It will be the fastest tire on a dry track by a small margin IMO but won't last very long and won't be as "enjoyable".
