Squeeling sound after rotor change
Changed my rotors out, they are now rotorpros. Bt whenever i turn left, whether lane change or turning, i hear it squeeling, no brakes aplied. Only to the left, not the right. Sounds more from the front left tire too. Did i do something wrong? What can cause it? Is it normal during break in?
I think any time you change the rotors, throw new pads in there. that way everything is new and nice. If i bit more lube dont work try and give them a rinse at the car wash. New pads and rotors will more than likely give you a small amount of noise at first. good luck!
Brake dust shield? It might have been. I took the wheel off the front right, the one making metal to metal noise when turning, and pulled the shield away a little bit. Put on a lil more lube, test drive this morning. I hope its not my master cylinder causing lack of pressure.
The opposite of that is true lol, you SHOULD replace pads when you resurface/replace rotors. What kind of squeal is it? High/low pitched? Does it make a grinding noise at all? How is the pad life on the pads currently?
003-EVO
22
May 22, 2017 03:54 PM
Grimgrak
23
Nov 15, 2012 06:49 PM
TxFAkuma
Aug 1, 2012 02:57 PM
Firebat
11
Oct 7, 2009 05:57 PM
