Too much camber?
Too much camber?
First off let me say I DD my car and do some spirited driving but no track.
So when I got my evo, I found that the right rear tire was wearing on the inside. All other tires wearing evenly. Figured it was probably just a toe issue. So I got new tires/rims, and lowering springs. Took it to an alignment shop expecting the right rear toe to be out of wack but to my surprise it was in spec.
The camber on the other hand was at -2.3* He tried to adjust it but could only get it to -2.2*
The other camber specs are FL=-2.0* FR=-1.7* and RL=-1.0
So is -2.3* causing the tire wear on my old tires?
there was no accident reported when I bought the car so really not sure about that. Another thing I noticed is that the toe on all of the other corners where out of spec positive, but the right rear was the only one that was already in spec.
Im thinking that maybe before I lowered the car, the toe on all the other corners were in spec and the right rear was out,
and after lowering it, it just so happened that it put the right rear into spec. and pushed the others out of spec.
Does that make any sense?
Sounds like the EVO was set-up w/a modest track alignment. If your DD'ing your EVO only, I would have it set up at the OEM spec
Also, Not sure why the mechanic could only stand up the strut to -2.2 (not much diff between 2.3 & 2.2). Sounds like an issue to me
Does your EVO have coilovers & front camber plates?.
Peace, Joe
Peace, Joe
No coilovers or camber plates, just hotchkiss springs. It is kind of weird that it would not adjust, I watched him do it, and adjusting the lower control arm eccentric bolt didn't change the camber hardly at all. Maybe he wasn't doing it right or something but it looked like he was adjusting it.
I really wish I had an alignment machine that was worth a crap. lol I work at a Diesel truck dealership and we have an old Hunter hunk of crap machine that we align trucks with. It does cars too just sucks setting it up cause we don't have a rack so its all done on the floor. I was gonna just do the alignment myself but after I got the machine hooked up one of the heads wouldn't turn on, spent two hours trying get it to come on but never could. Looks like I'll probably just wait until our machine gets fixed and do it myself so that I know its done right.
Yea I'm thinking thats what it was, as the toe on the right rear was different than the rest. As I've been researching, it looks like alot of people run negative camber and unless you run alot 3+ degrees, you shouldn't see much tire wear from camber alone.
TxFAkuma
Feb 17, 2017 03:45 PM
gunhaha
Jul 24, 2014 12:43 PM
