Brakes squealing only at low speeds
So I started hearing some brake squeal when I first bought my car (the car had 58k miles and the brakes were the same ones that were on the car out of factory) so it was time for some new brakes. Before doing any research I just went and bought some pads from advanced auto parts. Got them installed and I didn't take the time to do the proper bedding procedure. The new brakes didn't squeal at first but after a day or 2 they started squealing but about a week after getting the new pads my clutch wore out as well (long story short, my car did not get driven between January until late June so my car was in the same spot through very cold and very warm temperatures).
Once my car got fixed the brake squeal was still present and it was at the point to where it would only begin to squeal if I was going anywhere between 15 and 30 mph and coming to a complete stop and it was loud a loud AF metal on metal sound and I wanted it to stop. So last night I tried to do the proper bedding procedure and did 5 consecutive stops from 60 to 10 mph and then drove home without using the brakes as much as possible. It helped but I still hear some squealing when I'm stopping from a low speed. So I did some more research on here and found out that it can be caused by vibrations between the shim and the brake pads. So I followed the steps on getting the high temp anti seize compound and putting that between the brake and the brake shim to try and muffle the vibrations but my brakes still squeal.
Do I need to resurface my rotars? Or do advanced auto parts brake pads just suck? Any suggestions?
I went through bad brake squeal with my larger Brembos on my Volvo S60R and Evo. After several attempts on the Volvo, I found ceramic pads finally did the trick. Semi-metallics with the Brembos just sometimes squeal and there's nothing you can do about it. Even lubing the back of the pad or using the orange stuff didn't help. I even tried the Wagner Thermo Quiets (semi) and still had squeal.
Great post starscream....
my experience is that with pedestrian braking you will get squeal with more aggressive braking you will get reduced squeal.
light pedal pressure = squeal ,heavier / later = less squeal
Advance sells Wearever pads which are garbage. I wouldn't put them on a mini van let alone my Evo. Thermo quiets are a decent pad for daily driver duty, but they are expensive. Don't put lube on the backing of thermo quiets..they have a coating that is supposed to stop squeals. They will void your warranty if you use lube.
If you don't want to buy new pads, I would recommend getting your rotors resurfaced and scuffing the pads to remove the glaze. You can use sandpaper on top of a flat surface to scuff the pads. Put it back together and bed them in. Make sure to not hold the brakes at a complete stop when doing this or you can actually leave material on the rotor which can cause pulsation.
What about HAWKS Performance Ceramic brake pads? Also whats better getting the rotars turned or resurfaced? and can you do either of those things yourself without taking it to a shop?
I think that might be the problem aswell, I didnt know you werent supose to lay on the brake even if you were at a complete stop after doing the bedding process. Because when they do squeal its not a constant squeal, its more of a pulsating squeal.
Did you reuse both the metal and organic shims from the stock pads? I didn't realize there were two shims because one was stuck to the backing plate pretty well, but my ET500s squealed at low speeds until I put the second shim in. I removed/replaced the pads probably 4 times trying different methods to get them quiet before I figured out I just needed that second shim. They haven't made a peep since. Turning/resurfacing or replacing the rotors and not using poor quality pads are also highly recommended obviously.
I didnt know there were 2 shims, I only saw the metal ones. Could you possibly take a picture of the 2 different types?
didn't want to start a new thread so i will add to this one. i have evo 8 brembos, i know the brake squeal is caused by springs plate rubbing top of pads and grease gets rid of the squeal. i greased them, squeal disappeared. BUT the grease wears away. especially after rain. anyone know of something else that lasts longer instead of regreasing guide pins and springs plates every month?
4g63xawd
62
Jan 6, 2016 03:25 AM
AustinB768
12
Feb 14, 2013 09:29 AM
funks
58
Dec 20, 2012 11:34 AM
ekizenbe
16
Dec 16, 2011 08:11 PM
