18x9 rpf1
So with a 255/35 would I need to roll the fenders too? And I heard a lot of bad stuff about spacers failing or wheels coming off so I'm unsure if I really want that big of spacers
you have to run spacers no matter what size tire you want!!! the front rims wont clear the calipers, the 25mm spacer is required up front. you dont need spacers in the rear but i suggest getting 20mm spacers so it compliments the front. as for tire size, yes those pictures i posted are with 235/40....tires any bigger will definitely need a fender roll in the rear with a lot of camber up front. hope this helps you
as for spacers failing, i'm leaving that up to you and your research. i'll just let you know with proper bolt pattern hub centric spacers and proper torque......rims properly torque. you make the decision on that one bro.
I run the 17x9 +35. 20mm spacer needed up front, nothing needed in the rear. I run a 255/40/17 tire and wouldnt run anything skinnier. I dont think the spoke design on the 18 is any different than the 17 in the same width and offset. A rear spacer is not needed, only if you want. I wouldnt get a 20mm spacer in the rear though, that would be a little ridiculous in the rear.
dk3Jdefje1X
Jan 3, 2017 10:20 AM
nor11384
13
Jul 20, 2016 05:33 PM
WTB[MidWest]: WTB: Black 18x9.5 Enkei RPF1
RedEvoxGSR
For Sale - Wheels / Tires
Feb 14, 2016 11:28 AM
MivecAddict
12
Jul 27, 2011 07:26 AM
