Fender rolling question
Before I start I want to state that I did use the search tool already and found nothing that answers my ?.
I just ordered a set of Flat Black p45r 18x9.5 +20 wheels with 245/35 hancook ventus tires for my black Evo 8 that has a 1.8" tanabe drop (i think its 1.8" but could be off, cant remember exactly) because ive seen similar set ups and they look tough IMO.
Ive talked to Subydude at wheeldude.com and he said they may need a fender roll.
My question(s) is has anyone here had this same setup and if so did you need to roll the fenders? I dont have a camber in set or anything. Just had it aligned straight up for tire wear and I dont autox or anything. I know +20 is an aggressive offset so its gonna be close. Subydude told me with this set I wont need spacers or longer wheel studs which I would with the +30 offset. I am probably going to order the Professional fender roller anyway because I know I can prolly rent it out anyways. There is two brands of rollers. Easton and KTC. Both are identical looking but the Easton is 50$ More. Does anyone have any experience with The KTC? Also some tips, tricks, etc.. on fender rolling would be greatly appreciated. even though there is plenty of youtube vids out there.
Any help or opinions or PICS of that same set up would be awesome. THANK YOU
Luke
Luke
Sir
+20 IMO is way too aggressive for a stock body EVO. At the very least you will need a roll & a fender pull which most always puts a slight crease in the rear fender
You will need a rear bumper bolt relocate as well.
The prescription noted +20 / 9.5" / 245 is most certainly a "Stance" thing. You should have posted this in that thread
+27 & higher works much better.
Personally run a P45R street wheel 17 x 9.5 +30 / 275/40 tire. I have full suspension stroke w/ no rub. (Alot of rear fender work)
I have the exact wheel with yokahama S-drives on stock suspension.
Here is my advice, DO NOT roll your fenders... rolling fenders on evo's just doesn't work well, I highly regret doing it... seriously. The proper way to to alter your fender on an evo is to shave (cut is too much of a harsh word) the lip off the fender (not 100% of course don't be silly). The front you shouldn't need to touch, camber should take care of that. The rear will certainly need delt with, mine rubbed even on the stock suspension with the OE fender. Also, you may hit the rear bumper.
Again, do not roll your fenders... do not think you can do it yourself if you haven't done like 10 other cars....if you don't take my advice, you'll find out first hand why I gave it to you.
-Joe
-Joe
Sir
Personally run a P45R street wheel 17 x 9.5 +30 / 275/40 tire. I have suspension stroke w/ no rub. (Alot of rear fender work)
-Joe
-Joe
No problem Sir.
Here's my challenge for you. If you can get your wheel / tire set-up to do this (see pic) w/ the +20 & your stance 245 tire then you are "good to go". It you cant achieve whats in the pic, then it doesn't fit. Plain & Simple
EDIT: Use this calculator. It will help http://www.rimsntires.com/specs.jsp
Ok thank you. I was pritty certain that I was gonna need a role. Your response was what I was looking for. But you didnt need to pull your fenders? Just a healthy fender roll correct?
No problem Sir.
Im not looking to slam my Evo. I have a light drop. I hear across the board I just need to roll my fenders. Your the first guy Ive heard say that I need to have them pulled. What gives you this idea? Have you seen my setup that was only rolled and still needed a pull? Btw that picture is a little dramatic. Im not looking to tuck my wheels. Just want a clean ride.
That picture shows what the suspension looks like fully compressed. It's not "slammed". It's what will happen if you hit a huge bump at high speed, high load. The wheel will tuck up into the fender like it's supposed to.
If you have not properly clearanced your fenders, in this situation, the fender can cut into the tire turning an uncomfortable situation into a dangerous situation in less than a blink of an eye.
What he was saying, is that if you cannot tuck the rim and tire all the way up into the fender under full compression (Without contact), then you do not have enough clearance.
-Joe
-Joe
i just did my own fenders, first time ive ever done it. you cant even tell its been done. no waves no nothing. if you have half a brain and use the right tools it works just fine.
What set up were running for you having to roll your fenders?
I don't think you understand the point of that picture/post...
