Enkei RPF1 18x9.5 +38 fitment
Sup guys, new to the forums. So pretty much I'm the market for new wheels and the two that I'm going for are Enkei RPF1's and NT03's. So far no one has NT03's and they're all on back order for awhile so I might go with RPF1's instead. The local shop I have has them in 18x9.5 +38 offset. Has anyone run this offset? I'm currently on coilovers and I know fender work has to be done. My question is what kind of spacers and tires are best for this size? I have Ichiba 10mm slip ons right now but I might switch for normal spacers and ARP extended studs, I also have 265/35/18 Hankooks but I'm going to be switching them for a different set. Any help would be appreciated, thanks!
Welcome!
Here is a good read for you to click on...
https://www.evolutionm.net/forums/ev...s-go-here.html
Here is another one to click on..
https://www.evolutionm.net/forums/ev...ly-thread.html
And one more to click on.. :-)
https://www.evolutionm.net/forums/ev...faqs-forum-61/
Im not sure what the 18x9.5s need for spacers up front but the 18x10s need a minimum of 17mm to clear the brake calipers.
Other than that, just a roll flat in the rear and ~10mm pull up front was all I needed. I also have some custom trailing links to fit the tires in the rear but thats only needed on the 10's.
Welcome!
Thanks bro, currently going through them but none of them are in the 9.5 +38 :/
Oh I see. Ya the only offsets this shop has for RPF1's is 18x9.5 +38 and +15. I didn't go with the +15 because that's just too wide, but at the same time I want the aggressive look
The 'aggressive look' you want will require a lower offset...closer to +15...
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Heres a good thread to view which shows the same spec wheel: Wheels: RPF1, 18 x 9.5, +38 offset
Spacers: Project Kicks, +20mm, in the front only making it +18.
Tires: Dunlap Direzza Star specs 255/35/18
https://www.evolutionm.net/forums/ev...f1-teaser.html
cerevo (Feb 1, 2023)
FS[Northwest]: Enkei RPF1 18X9.5 - 38mm offset - Wheels only
awdboosted
For Sale - Wheels / Tires
11
Oct 30, 2015 08:33 AM
