Lug nuts for 18x9.5 +38 RPF1
Old Oct 1, 2012, 09:13 PM
illvolution's Avatar
Aright guys I have Enkei RPF1's in 18x9.5 +38 offset. I recently installed the Ichiba 20mm spacers with the studs for the front. For the lug nuts, the shop I ordered the wheels from told me the Work RS lug nuts will work. After putting the rim on the hub I noticed the lug nut didn't have much space to go in when tightening. Are these the correct lug nuts to use or should I have gone with a longer lug nut for example the Ray's ones? Or is the stud that came with the Ichiba 20mm spacers too short and I have to run ARP extended studs? Any help would be appreciated
Here's a link of the Work ones they gave me:
http://site.phantasmusa.com/blog/wp-...e-Anodized.jpg
Old Oct 1, 2012, 09:37 PM
EvilTechnology's Avatar
Are your spacers bolt on or do you use longer studs and slip the spacers over them?
I would hope they bolt on and have their own studs. In this case I'd bet the closed end lug nuts you bought are bottoming out on the studs before they are tight enough to securely hold the wheel on. I would use open end extended lugnuts.
Old Oct 1, 2012, 09:42 PM
It's these ones (I'm guessing they're the version 1?):
http://www.evasivemotorsports.com/mm...s_version1.jpg
Old Oct 2, 2012, 11:41 PM
boostless's Avatar
If those are the exact ones you got, then they came with extended studs. You got lugs nuts that are too short. Either exchange them for longer ones or get open ended ones. good luck.
Old Oct 3, 2012, 10:23 AM
I took it to a mechanic to check em out and it turned out the lug nuts fit good I was just being paranoid :/ haha but I'm going to be switching them very soon. Thanks for the help
EvoooB
For Sale - Wheels / Tires
May 13, 2016 04:42 AM
EvoooB
Northeast Region
May 7, 2016 07:00 AM
cfdfireman1
Sep 3, 2015 04:51 PM
bmxking45
Aug 18, 2012 08:29 PM
RAY101381
Apr 25, 2012 01:19 PM
Quick Reply: Lug nuts for 18x9.5 +38 RPF1
