Spacer option for MR bbs wheels?
depends on how you want it to look.
2 ways to do it. get bolt on spacers like project kics, h&r, etc that have studs built in
OR get extended studs all around and get slip on spacers. this is obviously the expensive and time consuming route but generally the preferred. ARP studs are best here.
if i had to do it i would prolly go with a 15mm or a 20mm for that almost flush look.
Thanks a lot guys. so then the spacers that already built in sutds aren't safer than APR extended studs + spacers?
I just heard lota horrible stories about spacers, like wheels fell off while driving, hard corner etc. 15,20mm seem pretty huge gab , are they safe to DD?
I had BBS and then went with rota P45r. I read a thread on here that you needed spacers to clear the brembos so I got 10 mm H&R. The car was fine with the same studs that were on the car and I believe they were just stock.
But right now I'm in the same boat as you. I have a different Evo now with the stock BBS and I'm looking to get them to stick out a little more. I don't have rolled fenders and rather not go that route so what would you guys suggest?
Mrswhite-evo
Jul 28, 2015 01:44 AM
JPLEVO
Jun 12, 2013 05:00 PM
mrowka
Feb 11, 2013 02:02 PM
AJCaron12
Nov 25, 2012 09:58 AM
