Outer Tie Rod out. Brand difference?
My outer left side tie rod is going out. OEM from Mitsubishi is pricing me $48 each. I plan on getting two just so i don't have to worry about either side.
My question is I go on ebay and find so many differently priced tie rods. I know you get what you paid for but i found 2 for $23 on there!!!
Has anyone messed with aftermarket tie rods? Experiences? advice?
please and thank you!
2006 EVO9 GSR
2006 EVO9 GSR
2006 EVO9 GSR
2006 EVO9 GSR
Consider what this part does and how the span of your life would be affected if it were to fail. That should put the cost in perspective.
Too bad companies like Moog have not stepped up to make a aftermarket replacement pieces yet. They would certainly be as good as OEM and you can get them over any parts counter easily
I have the Whiteline pieces as part of their Roll Center Kit. Did have to replace the boots as they were torn, which Whiteline generously shipped me for free
Just go to any Advanced and ask for them. It's about $25 a piece. I've bought Moog before and they do, in fact, felt like there was quality built into it. It was much heavier than the Whiteline and compared to the old OEM ones on my car, it was just beefier.
And my boots on my Whiteline also ripped. I heard Whiteline fixed the boot ripping problem but I would still replace the boots with OEM.
be careful when you go to advance or autozone, for some reason a lot of Evo suspension replacement parts I've tried to get from there were actually lancer parts or they didn't have them.. I've had good luck with napa though
I would be careful with the Whiteline stuff though... I was just replacing my axle today and found a torn boot on the driver's side tie rod from my RCA kit. Doing some research on the net it seems to be a very common problem. I'll be contacting whiteline tomorrow, hope they will send me some new boots at the very least. Hopefully the tie rod joint isn't trashed, I have no idea how long it's been torn like that. I have also been experiencing some clunking from the front passenger wheel area, it seemed to be rotational mostly on stop/start. That's why I was replacing the axles, assuming cv was bad. I've read of some clunking noises in subarus from whiteline's ball joints however, I'm really hoping it wasn't my whiteline ball joint making that noise. That'd be a pretty big waste of $ on new axles... Interested to drive the car and see if the noise continues, whiteline will be getting an earful if I had components of theirs fail on both sides of my car within two years of installation of their RCA kit. I will update when I hear back from whiteline and get the car on the road to assess whether or not the noise was due to the whiteline parts.
railgunner50
14
Jul 25, 2013 10:41 AM
OZ_kidd
Lancer How Tos / Installations
Feb 2, 2011 06:23 PM
hennessey01
Nov 2, 2010 07:10 AM
