Who`s running SWIFT SPEC R`s on an VIII GSR with stock KYB`s?
Just as the title says, and whats your opinion on it. Track/Autox/DD, how does it ride/ perform? Im thinking of doing this set up instead of the MR Bilstein/swift spec R set up. I know the Bilsteins are more comfy, but is the stiffness of the KYB`s benificial for track/autox?
I'd like to add a question to the discussion. Would it be unwise to install the springs in OP's question on an VIII that's been on stock springs/struts for 80k miles?
I would have to say its fine as long as the struts arent leaking, Im at the same mileage. I ran tein s techs for the last 20,000 miles or so and just put the stock springs back on because the s techs spring rate was way to soft to actually handle well. As long as the struts arent leaking or blown, it should be fine. But I have also heard your suppose to replace your struts at 50,000 miles. Seems a bit overkill but idk.
The KYB/Spec-R setup is slightly stiffer than the Bilstein/Spec-R combo. You can expect marginally less body roll with the KYB setup, but I would expect the Bilstein/Spec-R combo to handle uneven surfaces more easily without upsetting the car.
I run the KYB/Spec-R setup at the moment, but I would still prefer to have the Bilstein/Spec-R setup instead. Digressive valving is great to have just about everywhere.
^ Thank you for your informed response. Makes plenty of sense. I have also heard that the Bilstein/ Spec R set up is better for handling rumble strips on a track for that very reason of being more forgiving and not upsetting the car and absorbing the small bumps. Glad to get a response from someone that has experience running the set up in question.
I have been on swift spec-r springs on my stock MR bilsteins for about 2 years and they have been great. The only other spring I would even consider are gtworx. If you are picking up a used set of bilsteins I would suggest sending them in to get revalved for your new springs prior to install. This way you know they will be good to go for years to come.
