NRG Innovations Rear Toe Control Arm - EVO 8?
My question is does anyone here replacing the stock unit with this unit? My rear toe link ball joint is going out, and I don't want to spend 300 bucks for just one side. I wonder if this unit is the right replacement for stock one.
http://www.lancershop.com/customer/p...cat=105&page=1
I've got the DME rear toe arms and they are pretty stout. They use heim joints instead of ball joints. They've been on the car for a couple hundred miles so I can't say anything about longevity. The alignment shop loved them cause they always have problems getting my toe set.
Interesting. Anybody checked range of motion on these? I'm wondering if there is enough uni-body clearance and joint angle to let these work on a lowered car.
Between those and the eccentric you could probably dial out the rear bump steer without relying on a lousy eccentric bushing.
Funny you asked that. I was in such a hurry that I never even checked the clearance on the body.
I had to look and I'm pretty low in the rear (tire sits level with quarter panel) and there is about 1/2" till the pinch weld. If extra clearance was needed the pinch weld could be ground out for another 1/2". How much travel that amounts to at the wheel, I'm not sure but I would imagine a good amount of travel.
http://www.meganracing.com/product_d...d=938&catid=96
I took a look at that last time I was down in the back and didn't see any indication the toe arm was smacking into the frame. I am only lowered ~1" in the rear and there would have be some significant suspension travel before it makes contact. On a car that is lowered significantly, there might be concern. You can sort of see in this picture where I am talking about:
I believe this is the correct Nagisa version which has more room for the pinch weld.
http://www.vividracing.com/catalog/n...-p-108327.html
Next time I am under the car back there I will take a look again to see if there is any denting to indicate that these are hitting the frame.
I've got an axle to change this weekend so I'll take some measurements and figure out the travel of the inside of the toe arm compared to the wheel travel.
I'll check the heim joint movement as well but I figure it probably has better travel than a ball joint.
Hiem joint + tapered stud + offset spacers = win
Anybody ever checked the bumpsteer characteristics in the rear? Obviously whiteline found something of concern to offer the eccentric bushings. Just curious how significant it is.
I have most of the parts measured and modeled up, just haven't gotten around to measuring up the hub carrier to complete the model to answer this question from a theoretical stance.
