Alignment Specs.....lowering evo tonight i hope
Alright, well i think the Stech's are gonna hopefully be put on tonight....when i go to get an alignment what spec's should i try to shoot for?? I dont want my tires to start wearing out prematurely...can you guys post some specs after being lowered so they wont wear soo quick?? thanks, and also will the dealer be able to align it??
I think most dealers have an alignment machine. We have one at my work that you can do alignments for any make/model on.
I don' tknow about specs. I haven't got coilovers yet.
You realy can't do a front wheel alignment on the Evo. I replaced the springs, S-Techs, myself and noticed when I removed the brake assembly and then the strut there was no room for adjustment. Brake assembly bolts to the strut, strut to the car, that's about it. Camber adjustment would be helpful. But honestly I haven't done a thing since I dropped my Evo and it's perfect. No steering wheel shake at any speed, low or high, no tire wear, all is well. I will bring it in here in a few to get it check out to make sure.
after you lower the car, go to just tires. they will be albe to do adjustment, i did. just in case i dont wanna ruin my advan's
he says front was ok but needs a little adjustment so he did rear was worse then front but not bad. and 1 toe was messed up.. so go figure.
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
N1MR0D
Jul 4, 2017 08:47 AM
TxFAkuma
Feb 17, 2017 03:45 PM
samterry1234
18
Dec 30, 2011 08:49 PM
Mooshu1221
12
Feb 2, 2005 05:14 PM
