Heading to the Road Course with stock suspension......alignment suggestions?
Hankook R-S3
Would like more camber as I've previous tracked cars with stock suspension and I keep rolling over the sidewall to the point where there would be paint on the sidewall.
I've read else where Toe should be 0 all around and Camber should be:
F: -2.0 to -1.5
R: -1.5 to -1.0
Is that close? Would F-2.0, R-1.5 be too much camber for the rear? I imagine with Evo's and their struts, the more camber in the front, the better.
What about stock caster adjustments? Can you even adjust stock caster front or rear?
F: -2.0 to -1.5
R: -1.5 to -1.0
^this^
You'll have to work to get that much camber front but it can be done. R-S3 is a very good tire for the track lots of feedback and grip. Start at 36 cold go to 42F-44R hot.
You can get a little bit of caster adjustment front by moving the cradle but it's not worth messing with.
my first few times on rs3's i ran 32 cold and got them to 38ish hot. this past weekend with a 32 base pressure, and an experienced evo guy/instructor flogging my car, his biggest observation was a lack of front grip. the tires had heated to 40+ psi.
42-44 seems little hot imho.
but this also depends on tire size and rim size.
TxFAkuma
Apr 15, 2016 04:12 PM
PaRanHaNeul
16
Nov 7, 2008 05:08 PM
Ludikraut
15
Aug 3, 2006 01:02 PM
BIGWING
Sep 9, 2003 08:05 AM
