Popping noise from DS wheel well???
Hey guys, so lately i have been hearing a popping noise from my drivers side wheel well. It seems to only happen when i press on my brakes hardly, or when i either hit a dip in the road or a speed bump. Could this be something wrong with my suspension? Does anybody have the same problem? I have an 05 evo 8, with stock suspension and brakes. Thanks for any responses.
The guys here can sometimes diagnose conditions but may need a bit more info.
Jack up the front & place on jack stands
Push the wheel & tire in & out to check for loose bearings.
Pull the wheels & using a light, check for any loose components
Make sure the strut connections are tight. Shake the strut for any looseness
Check for worn bushings, cracked CV boots etc, etc
kyoo
29
Sep 28, 2016 06:23 AM
Jim3142
23
Jul 22, 2016 07:49 PM
DrBump471
Mar 12, 2008 12:38 PM
