work emotion xd9 17x9.5 +28 fitment on evo ix wagon?
Hi guys
Ive found a set of work emotion xd9 17x9.5 +28 and i'm just wondering if they will fit an evo ix wagon? and if so what fender work, spacers will be needed if any?
car lowered on swift springs
Attachment 333103
cheers for your help guys!
Attachment 333103
Sorry cant help w/the spacer question. Not familiar with the XD9's.
Also, Not at all familiar w/the EVO wagon rear wells. If they are similar in size to our 8's & 9's then:
17x9.5 +28 will fit up front no problem (liner rub possible depending on tire & suspension at full lock)
Now, depending on your tire choice, it is likely you will need rear fender work. A modest tire would be the 255/40 in which a roll & slight pull will be needed using stock camber settings
thanks for the info MinusPrevious!
hmmm im not keen to pull the rear, at the most a roll is all i really want to do. what about a slightly stretched 245 tire?
my other option is the xd9 18x9 +30 it fits but has a lot less dish, could be the easy option though!
My understanding is that the wheel wells are exactly the same as the evo 9.
cheers
cheers
these are the size options and dish depth:
Sizes:
17 inch:
17x7 +42 / +47 / +53 (37 mm deep dish)
17x7.5 +32 / +42 / +50 (39 mm deep dish)
17x8.5 +32 / +42 (46 mm deep dish)
17x9.5 +17 / +28 / +38 (68 mm deep dish)
(PCD 4H-100 to 114.3 / PCD 5H-100 to 120)
18 inch:
18x7.5 +48 / +53 (37 mm deep dish)
18x8 +35 / +45 (37 mm deep dish)
18x9 +20 / +30 / +38 / +43 (45 mm deep dish)
18x10 +18 / +38 (73 mm deep dish)
Sizes:
17 inch:
18 inch:
cheers
cheers
The 18x9 +30 just about puts you in the same boat if you run a 35 series. Would look a lot better w/a 245/40/18 but its a tall tire & will require more fender work
It looks like youve done your homework because the offsets you have picked are aggressive but very doable providing you do the modest rear fender work
The more serious issues occur w/guys picking these super poke stance setups & rolling in out of spec camber. They never really fit right
LSD Motorsports
EvoX 'For Sale' Wheels / Tires
156
May 6, 2017 06:01 PM
LSD Motorsports
Dec 21, 2015 10:58 AM
RavSpec
Evo 'For Sale' Wheels / Tires
Dec 13, 2013 03:48 PM
RavSpec
20
Nov 30, 2013 10:45 AM
