Wheel offset?
Wheel offset?
I'm looking for a slightly better suspension and some wider wheels to stuff under the evo. I dont know how this offset stuff works as I never had had to mess with wheels that were not stock or from another vehicle of the same family. So my biggest question that I cannot find the answer to is what the correct offset for my evo viii or what is the minimum and maximum offset?
Camber change is the number of degrees of camber that the front wheels lose or gain from static (down the straightaway) to dynamic (in the middle of the turns). There is an optimum amount of camber change for each of the front wheels. The amount of track banking is an important factor in determining the best design for your car to produce this change.
Rifle through the attached file. After some study you will begin to see the average range of offset & tire width
https://www.evolutionm.net/forums/ev...s-go-here.html
Unless your willing to aggressively massage your rear fenders I recommend using offsets above the +30 range (+30 to +38) & dont mess w/your camber settings to fit. Please note: Camber & ride height have nothing to do w/proper fitment
Thank you, I'll read up
lancerman360
91
Apr 22, 2016 03:01 PM
Chamama
Jul 29, 2005 06:58 AM
rota wheels
Jan 22, 2004 02:17 AM
