2piece rotors or brake ducting?
Did you relocate the ACD pump?
I need to test mine to see how the flow is before I get the car back together, I think the kink in mine around the pump is ****ing with my driver side cooling.
Been done. An acquaintance of mine who wrenched for Indy ran a watercooled set-up on a souped-up 50's Renault.
Also has been done on GT-R's:
http://www.willallracing.com.au/gtrbrakes.htm
I know someone has tried this if it were a viable idea, but what about a small nozzle that sprays a little mist in the center of the vents in the rotor to cool it? Or a heat sink on the caliper? Or just shooting a few psi of compressed air in there? Wastegate dump into caliper vents!
That water-cooling idea is nice. I wonder about something like that working just like the intercooler spray setup, just instead spraying into the rotors. The water is a better dissipator of heat than air, correct?
yeah thats pretty much what i have. im sure theres some pressure drop due to the bends, but its better than nothing. maybe my racing brake pistons make a bigger difference than i though.
Smike
628
Oct 27, 2024 04:39 AM
Smike
63
Apr 29, 2019 07:27 AM
golgo13
37
Apr 4, 2014 04:32 PM
