PS pressure hose o rings
Can someone helps me source the parts or get the part numbers for the orings that go above and below the oil line fitting on the top of the power steering pump?
My Evo dealer says there are no such orings in his parts software, but I have the FSM indicating the parts.
Correction:
Those are rubber O-rings and you may have to order the entire PS pump repair kit to get them. I did not replace them ever. They are over 10 year old and do not leak. Sorry I was thinking about something else when I replied.
Just need a bump to get some clarification from anyone that has taking this apart from a stock setup. Are the 5N markings indicating the two differently sized o rings that actually mount on the shaft? Or are those 5N items additional orings that seal between the base of that shaft and the lock washer?
nor11384
Apr 29, 2017 09:25 AM
NSXLVR
Mar 14, 2017 02:46 PM
FS[Northeast]: PTE 880cc Injectors
KJS
11
Feb 19, 2016 03:48 PM
