how to remove pad deposits from the rotor ?
![Question](https://www.evolutionm.net/forums/images/icons/icon5.gif)
have seen quite a bit of posts that say rotors do not warp, they just have uneven pad deposits that cause vibrations when breaking
my car acts the same and I'm not quite positive to turn the rotors and remove some life from them. so is there any DIY way to clean rotors ? will sandpaper do the job ?
it began when I braked hard from ~110mph an experienced so called break fade. after that every time my brakes get slightly hot it vibrates when stopping from ~60 mph
how to resurface rotors for DIYers and shade tree mechanics.
Op ive been there.inspect your rotor surface from both sides first. Are they evenly flat or one side is more rough then other.the reason is if wear is uneven it might be your caliper pistons not clamping evenly.in my situation i had to purchase caliper seals from rock auto.thanks to our friend cfdfireman1 here
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
