10mm wheel spacer and stock studs
Old Jan 6, 2015 | 07:08 PM
supaduckie8113's Avatar
I just picked up a new set of rims and i need to run a 10mm spacer up front to clear my calipers. Do you guys know if the stock wheel studs are ok to use with a 10mm spacer or do I need to run extended studs?
Old Jan 6, 2015 | 08:31 PM
Siluck2's Avatar
I wouldn't run that on stock studs.
Old Jan 7, 2015 | 07:45 AM
heel2toe's Avatar
Naga naga nagunna happen
IIRC something like a 3mm spacer is the max you could get away with on stuck studs. If you need to run a 10mm spacer they do make some bolt on types however I am not to keen on those albeit not from experience because they scare me.
Your best bet is to pick up a set of ARP extended studs and a slip on spacer. Installing extended studs are cake especially in the front and they are relatively inexpensive as well.
What wheels are you trying to fit?
Old Jan 28, 2015 | 11:14 AM
evanwest94's Avatar
spacers are not the most reliable thing. but if you must. get a set of balanced 10mm hub centric type adapters, you may be able to run just a 10mm spacer depending on the lug seat of the aftermarket wheels you are gong to run, mag seats will be able to go deeper into the wheel to get more threads but you really want to have the maximum amount of threads allowed to ensure the proper torque over time. what I would do is test fit them and see what you need. check where they would rub and also check how much thread is exposed. like the above said, an extended stud would be ideal but you really want the torque point to be as close to the hub.
Old Jan 29, 2015 | 09:23 PM
mrfred's Avatar
i just experimented with 3 mm and 5 mm spacers. 5 mm has about 5 threads of engagement and is the max i would run. 10 mm would have maybe 2-3 threads at best. definitely disaster waiting to happen.
Old Jan 30, 2015 | 10:04 AM
dc206r's Avatar
NO more than 5mm. If you need 10mm, I'd find some with studs on them.
supaduckie8113
12
Aug 6, 2013 01:44 PM
Hi Im Vinh
Aug 26, 2012 01:32 PM
jgray2010
Oct 26, 2011 03:06 PM
_des_
For Sale - Wheels / Tires
Sep 20, 2010 02:11 PM
hks-mr
Oct 5, 2007 11:44 AM
Quick Reply: 10mm wheel spacer and stock studs
