Help please!!!
Old Feb 2, 2015 | 01:52 PM
WillH3rrin's Avatar
Help please!!!
Hey guys!! Lately I've been having this issue & it's really frustrating. I have a 2006 Mitsubishi Evolution MR. Whenever I go over bumps, the car feels loose despite the fact that it has a brand new ISC N1 coilovers. At first I thought it was the strut & shocks so I replaced it with ISC N1 coilovers design for tracks. It changed slightly but the main issue is still there. The car still feels loose over bumps & it's not handling well as it should for a car that is built for rally. Probably has severely worn sway bar bushings. Wheel bearings and worn tie rods and ball joints? Help please!!!
Old Feb 2, 2015 | 02:47 PM
llDemonll's Avatar
what do you mean loose?
are you going slow or fast over these bumps?
have you had the suspension set up by someone who knows what they're doing?
Old Feb 2, 2015 | 04:29 PM
WillH3rrin's Avatar
Fast, slow & regular. Yup, I had someone who knows what they are doing. What I mean by loose is that, the handling is not there. U can definitely feel the front as u go over the bumps despite the fact that the suspension is adjust to where it can absorb the bump. I beleive the coilover is not the issue here. Thanks!!
Old Feb 2, 2015 | 06:21 PM
Very difficult to diagnose these comments on the net. Loose is a suspension term meaning tail out or oversteer if that is what you mean
If thats the case, knowing you have newly installed C/o's, its possible the suspension rake is way off. Likely the frame rails are too high in the rear
One of our epic threads that died too quickly discusses rake
https://www.evolutionm.net/forums/ev...bout-rake.html
Old Feb 4, 2015 | 12:00 AM
dc206r's Avatar
I would probably check bushings and other endlinks and whatnot first. If your car has a decent amount of mileage on them, they probably need replacing. Those are wear items that should be changed out sooner or later.
Old Feb 5, 2015 | 01:46 PM
hoobastnk90's Avatar
I think i had the same issue your saying when ever i would hit a bump the front would take it but it would feel like the rear of the car was off or something like it would want to slide out or felt off balance is this the problem you are describing?
Old Feb 6, 2015 | 06:06 PM
AJCaron12's Avatar
It sounds like you replaced your stock struts with coilovers, thinking that this would fix your original issue. Not a smart move. Put the factory suspension back into the vehicle, and then diagnose your problem from there.
Old Feb 6, 2015 | 08:55 PM
wvrx's Avatar
Check your wheels for play. Jack the car up and inspect the bushings for wear, depending on your mileage some may need replaced - the car is already 9 years old.
Old Feb 7, 2015 | 08:52 PM
sssr20det510's Avatar
Have u had the car aligned? If not take it in and have it aligned they usually check your suspension before they will align it.
Old Feb 8, 2015 | 12:16 AM
Avari's Avatar
Sway endlinks/bushings will usually clunk no matter the speed. I presume the coils came with new camber plates as well?
Old Feb 8, 2015 | 12:00 PM
WillH3rrin's Avatar
Hey, yes!!
Old Feb 9, 2015 | 12:17 PM
which thing were awnsering yes to lol there was like 5 suggestions?
Old Feb 14, 2015 | 11:16 AM
egis's Avatar
op said Yes because after the boost leak test he found out he needed alignment.
nlp187
Jul 8, 2012 10:32 PM
DIDYSIS
May 9, 2009 04:30 PM
AlliGirl
Northwest Region
Sep 17, 2003 12:55 PM
Quick Reply: Help please!!!
