G-sensor or ABS sensor?
I bumped into a curb a while back. I had to replace the wheel and wheel bearing, thinking that the ABS sensor would come with the wheel bearing, which is does not. However after the fact, ANY time I press the brakes I can hear and feel the ABS unit working, but the wheels are not slipping. So I assumed it was RR ABS sensor that was bad. When looking the ABS sensor up I noticed a G-sensor for sale.
The wires on my RR ABS sensor are all okay. So I'm not sure if that ABS sensor is bad or not. After seeing the G-sensor, maybe it's that.
Anyway I can test both or them to make sure which one is bad?
Or what about using a Snap-On scan tool to read some info?
Need a scanner that will display ABS codes, and all 4 wheel speeds (not just vehicle speed) to determine whats going on.
Sorry for bring this back from the dead but I put this on hold until now. I do have a Snap-on scanner and will check it tomorrow to see what I can find. I really hope I can see wheels speed and what not.
doncarbone
14
Jun 17, 2016 02:08 PM
FS[Northwest]: RS non abs/abs delete prop. valves bnib mr249607
420a-t
Dec 23, 2014 10:17 AM
