what is the max stock camber adjustment?
My alignment shop seems to be able to get only -1.2 at most. They can get it to -1.8, but it keeps readjusting back when they bolt it back up. What is the max, most agressive camber setting that someone else has gotten, stock?
Last year, my shop got -1.8, which seemed to be consistent with what most folks were getting. I will be getting another alignment next week in anticipation of the upcoming AX season, so we will see if a year of driving over potholes and such has loosened/bent things up enough that we can do better than that.
is such a tease with that -2.5 spec...
JW
![Mitsubishi Logo](https://www.evolutionm.net/forums/images/smilies/mitsu_logo.gif)
JW
Originally posted by eclipsegs2k1
I thought you could get -2.0?? For the guys that have got it at 1.8, does it handle noticeably better?
As for how much of a difference it makes, I really couldn't say. The autocrosses I ran before the alignment were on the original A046s, the autocrosses after that were on R-compound tires. Definitely apples and oranges...
JW
Yeah, you definitely cannot compare that. So what most of you guys are getting is a little under -2.0 degrees, but if it were possible, you could run -2.5 degrees? I am just curious about this stuff. Thanks for the reply jwtodd.
JW
JW
JW
