road v track wheel alignment
I use my evo mostly for weekend canyon drives and track days, last time I got a set of tyres I remember the tyre guy saying that some track guys setup their wheel alignments specifc to track days, so what does this actually mean? I thought wheel alignment is the same for track and road, can you actually make your car handle better on tracks by doing a different wheel alignment?
Running a lot of camber on the street will wear down tires quicker than with less camber. Increase camber at the track to improve speed through corners. The idea is to use the entire tires contact patch with the tarmac. If you don't have a lot of front camber and you enter a corner you're going to roll into the tires outer edge, thus losing front end grip, thus turning a slower lap time. This is just one example. Make sense?
How do you figure? On the street most of your driving is in a straight line and you dont take turns/corners are high speeds. No need for your camber be like this /---\ there is less grip in a straight line because only the inner part of the tire is being utilized. You can run a lot of camber on the street, you'll just go through tires quicker.
I run my track specs on the street. Toe is what really wears tires, camber not as much as you would think. But your specs should be towards your car and your driving style.
when my car was on driven on the road as well as track I ran (-2) Front (-1) Rear and Zero front and rear toe.
my car is now track only and I run (-5) Front (-2) Rear, 4mm Toe out in the front and 1mm toe in on the rear.
the rear toes setting is not great, needs work.
As has previously been stated a heap of toe will wear tyres more than camber as the inner/ outer depending on setting is being dragged basically because it is not pointing straight
raytrix
Jan 30, 2011 05:51 PM
namwens
Nov 4, 2009 01:13 PM
1993blackz28
Jan 27, 2008 02:23 PM
andber
May 28, 2007 10:16 PM
