Pls help/advice tire size
Old Aug 16, 2015, 09:20 AM
Ang Wen Yan's Avatar
Originally Posted by DsmEvo87
Thanks for all your input guys really appreciate it, this seems like a tough call....
My main reason for trying 235's would be to fill the arches a lil bit.
Plus the tires Im fitting ( goodyear eagle f1 asymmetric 2) Im also told these tires arent as wide as some others on the same size
If you really want to fill the arch upgrade to 17x9+35 wheel and 255/40/17
Old Aug 16, 2015, 09:59 AM
DsmEvo87's Avatar
Thanks, sadly new wheels arent on the budget atm, guess I'll have a look on getting spacers
Old Aug 17, 2015, 09:19 AM
Your best bet is stick to 225/45/17 and install some spacer
Old Aug 17, 2015, 12:28 PM
DsmEvo87's Avatar
Thanks so much bro would go this route.. on a sidenote would you recommend the goodyear eagle f1 asymmetric 2 or the michellin pilot super sports?
Old Aug 17, 2015, 02:11 PM
LetsGetThisDone's Avatar
Received 1,571 Likes on 1,348 Posts
The Michelins are the best tire in that category. Bridgestone re760's and BFG Sport Comp2's are both a close 2nd. The good years are garbage.
Old Aug 18, 2015, 08:14 AM
DsmEvo87's Avatar
And from the UK crowd Im getting GREAT views on the F1's as Ive posted on the tires section on lancerregister.co.uk
:/ Seems cant go wrong with either 1
blkmamba
Mar 21, 2011 12:31 AM
the4thpower3
Jul 26, 2009 11:53 AM
bbyevo8u
Aug 20, 2007 01:21 PM
darkjediii
Jul 16, 2004 01:52 PM
Quick Reply: Pls help/advice tire size
