Ohlins Front Suspension Noise Over Bump/Holes
Seeing if anyone has ever had this issue. There's a clank-like sound coming from the front left suspension every time the wheel goes over a bump or pot hole. My suspension setup consists of Works Ohlins DFV Coilovers with Works camber plates.
Could it be the front strut is blown? Any advice would be great, thanks.
EvoM Community Team
I get this. I just ignore it because the shocks aren't blown, the alignment was done recently and I have aftermarket parts that probably don't fit 100% perfect like OEM. Sway bars, polyurethane bushings and Perrin Endlinks.
https://www.evolutionm.net/forums/ev...ion-clunk.html
https://www.evolutionm.net/forums/ev...ise-front.html
https://www.evolutionm.net/forums/ev...ing-noise.html
https://www.evolutionm.net/forums/ev...end-car-2.html
Thanks, I thought so, local shops couldn't diagnose it. Links were very helpful.
check the top shock nuts... those can come loose
Yep. Anti roll bar end links are a usual suspect for what you describe. They can come loose over time, or possibly weren't tightened well during the ohlins install.
kf6ytc
Oct 16, 2006 08:38 PM
forum04pl
Mar 16, 2005 09:45 PM
forum04pl
Feb 8, 2005 12:55 PM
