I need these wheels!
Wheels are Cosmis XT-206R.
You are going to need some serious work done to get these on. I almost got these but was talked out of it due to what needs to be done to get them to fit.
fjm9898 has them. Check out his build : https://www.evolutionm.net/forums/project-cars-build-threads/640915-mad-cow-6.html
Originally Posted by KJS
18x9.5 +10 would be doable with SERIOUS rolling in the rear and like a 245/235 with a 35 sidewall.
18x11 + 8 is more or less impossible expect a lot of custom wide body work
fjm9898 has them. Check out his build : https://www.evolutionm.net/forums/pr...mad-cow-6.html
I believe the WRX'S have narrower rear wells than our EVO. Their std offset is over +40. If you read the wheel threads on Nasioc, their wells are less forgiving, in stock trim, than ours
Anyways, FWIW, Not a suby fan w/their boxer motor & complicated exhaust, alum & open deck block. Thats why i drive EVO
ricanevo
18
Nov 5, 2008 12:32 PM
alby988
22
May 17, 2005 12:22 AM
mb500
Jan 10, 2004 11:13 PM
