better to buy 8.00,8.25 or 8.50 x17 tyres?
Sorry I meant "rims" above not "tyres"...woops
Guys, just looking at getting a separate set of 17 in rims for track work, I have noticed you can get wider versions of the 17s, will there be any advantage getting the wider rims? I'll be running 235/45 or 245/40 tyres so not wanting to roll my guards. Will a 8.5 width rim suit a 235 or 245 width tyre better or not worry about it and stick to 8 inch wide?
For example, 245/40R17 is the go-to size for those of us doing autocross in the STU class. The go-to wheel for this setup is 17 x 9.5", which is also the widest wheel recommended by most manufacturers for 245-width tires.
You can fit 9.5" if you're careful about offsets and brake clearance. You'll have to run a reasonable amount of camber to avoid contact with the fenders, but it's really easy if you go with a known-good setup.
8.5" or 9.0" would work as well if you don't want to push it.
I run 2 diff sets of 17's for reference
17x9 +29 w/a Nitto 255/40 = Track only
17x9.5 +30 w/a 275/40= Street only
Its your choice. I would go w/a 17x9 wheel & run a 255/40 (this is the wide EVO standard IMO) & roll those fenders
BTW, if you are having to add camber to get your wheels to fit, then they dont fit ! Never add camber for fitment !
After allot of searching and asking questions, I settled for a 9j, et30 wheel with 245 tyres.
Lowered on Tein coilovers, zero rubbing and fills the arches well enough. For me, both functional and aesthetically pleasing.
235 would require an 8.5j rim.
My mistake. Although I cant understand how. With 245's on my 9J, the
tyres have a bit of stretch already. I can only imagine that the 235's will
stretch even more so.
trev555
13
Sep 28, 2002 01:09 PM
franco209
Apr 18, 2002 11:11 PM
