ce28 18x9.5 +42 for $700
a 10mm spacer all the around should suffice to make them fit well with a 265/35 or 255/35 tire and rear fender rolled flat and pulled a bit. Not sure if that will clear the brembo's though. You may need a bigger spacer up front, which is fine. The front has a lot more room for lower offsets than the rear.
Too large of a spacer up front would be a concern IMO. If you need something greater than 25mm, I would be concerned (dont like spacers, at all, if you ask me)
I would also make sure they're real Volks. $700 is awfully cheap for a set of wheels that retails for over $3k...
They're real the guy who had them knows nothing about cars he got him on his car of the lot which is why he had them and the curve damage is minimal nothing too bad
Rear clearance to the lower control arm maybe an issue depending on what tire you choose. You may need a rear spacer as well
EDIT:
I have 18x8.5 with 235/40/18 and do not use spacers.
Before you go ahead and order a set of spacers, mount the wheels on one side of the car and go from there. If they fit, drive on them for a little and make sure they're not complete trash.
johnnnyjeans
For Sale - Wheels / Tires
Apr 23, 2014 09:04 AM
e-autosports
EvoX 'For Sale' Wheels / Tires
61
Nov 16, 2009 07:31 AM
A-SPEC
Evo 'For Sale' Wheels / Tires
75
Nov 8, 2007 07:49 PM
A-SPEC
48
Jul 27, 2007 02:58 PM
'ringmeister
Sep 21, 2006 05:57 PM
