Brakes spongy after Girodisc caliper rebuild
If your problem turns out to be the MS, it's actually pretty easy.
I'd make 100% sure all the air is out of the system, first. Tap the calipers with a mallet, let them sit, pressure bleed...whatever you have to do. Also, let the ABS unit cycle, as mentioned above. No sense in replacing anything until you have to.
Download the service manual. That will answer a lot of your questions.
After letting the car sit overnight after the abs was cycled I pressure bled the system again. Some small bubbles but nothing significant. After this didn't work well I went to the method like a post stated earlier of putting the pressure bleeder on and removing each line on the abs unit. It did seem to remove some air, but my pedal travel is still about 1.5" with the car turned on. The manual says it should be .8" guess I will drop the car and see if maybe 1.5" was my norm. Either way looks like I will need to buy a master cylinder rebuild kit. Thanks for all the input so far.
forgive me as i didnt read the whole original post, but i figured id share this:
when i have rebuilt my calipers and had them be completely dry of fluid, my power bleeder has not been able to handle the bleeding. I wound up using the power bleeder to get everything close to done, and when i still had a mushy pedal i moved over to the old fashioned friend in the drivers seat, and low and behold got a pretty decent sized bubble out of each caliper. Went back to the power bleeder for al ittle more fluid and boom they were back to nice and stiff.
i have found that air bubbles can still get trapped using the power bleeder.
I also didn't even think about this, but what did you lubricate the seals with? If you didnt put it together with brake fluid, the seals can be sticky, and pull the piston back to far, which would result in a long/mushy pedal..
I made sure to put all the seals fully into some new ate fluid. I also lubed up the pistons. They were pretty difficult to get back in straight. I have ordered an oem brake master cylinder rebuild kit (hopefully for the larger abs unit and not RS version) and I also bought some new bleeders for the calipers. Might try to do an old fashioned 2 person bleed another time or two.
If OP says he split his apart then it would make me thing "hmmm".
**edit: this is all i could find. just a lot of hearsay. It's pretty much what i read (i think). I have to imagine if we're half-way competent, splitting them shouldn't be a problem LOL. Unless I can find that other thread and it has different info.
https://www.evolutionm.net/forums/ev...bo-brakes.html
Hmm, no valid reasoning for all the "OMG DON'T DO IT"...lol
i very rarely hear of success stories on the first try when people split them. more or ings to risk etc imho...its not all that difficult too do the rebuild without splitting. ive had my pistons out like 4 times in 3 years...zero issues.
The fronts have an external crossover, what oring is in them?
