Rear camber bolt won't get tight
My right rear camber bolt will not get tight. I can crank on it as much as possible but it still will move. Doesnt look stripped or damaged. Do i need a new bolt or lower arm?
Junkyardspecial (Apr 1, 2016)
New bolts solved everything. I had an issue with how it wouldnt tighten but when I finally got around to getting under the car (its been raining here non stop) I saw the problem and its good as new, thanks for the help
http://www.streettunedmotorsports.co...t_bolt_kit.htm
http://www.streettunedmotorsports.co...t_mb809343.htm
http://www.streettunedmotorsports.co...t_nut_bolt.htm
The last link is for the front but it comes with the nut that is also for the rear suspension bolts. I would contact STM so you can specify that you only want part number MU431006.
overdrive1
Aug 11, 2015 06:13 AM
Mivo
Northwest Region
12
Jul 8, 2011 02:15 PM
R0ME0
Jun 18, 2009 11:55 AM
monstar 8
19
Sep 18, 2007 01:51 AM
