Work CR Kai's 18x9.5 +30
I have a set of CR Kai's 18x9.5 +30 offset a buddy of mine gave me his hub centric 15mm spacers. I know you need at least a 10mm in the front to clear brembos. I'm just wondering if I can run 15mm all around and throw them on?Or am I going to run into to many problems and should sell ? I would be putting them on a Evo ix.
You can certainly run the 10mm up front & that will work Ok depending on tire choice
Running a 15mm in the stock rear will cause all sorts of fitment issues leaving you w/a +15 offset. Just run the wheel w/no rear spacer & depending on tire choice is your best bet
If you give me your tire choice Ill run you up on the calculator
MR06Evo
10
May 30, 2007 06:37 AM
TeKiZeRo
For Sale - Wheels / Tires
13
May 29, 2007 07:30 PM
EVIL VIII
Mar 14, 2007 02:45 PM
Speed Element
Evo 'For Sale' Wheels / Tires
Jun 13, 2006 04:40 PM
A-SPEC
98
Apr 4, 2006 12:34 PM
