Rear Brembo Caliper Mounting Points?
Are the stock Evolution Brembo 2 piston rear calipers the same from the Evo 8 and the Evo 9? Does anyone know what the piston size is on these rear calipers?
Also, I would really appreciate it if someone could measure the center-to-center distance of the caliper's mounting holes. I'm trying to see if these calipers will line up on a different application
No, Evo rear are different, they don't bolt on in place of 8/9 rear calipers. The fronts you can, but the hole in the spindle has to be drilled for the larger 14mm bolt that the X front calipers use. And with the X caliper, you need to run the larger, 13.8" X rotor..
Good to know, thanks.
I found out that the Evo X's Rear caliper mounting distance is 146mm center-to-center
Would be really helpful to find out what the Evo 9's rear caliper mounting distance is.
Huetsimus
Jul 5, 2015 04:19 AM
franc01
Apr 20, 2015 09:00 AM
akunochi
Site Feedback / Suggestions
79
Jul 23, 2008 05:59 PM
Juan Martinez
10
Aug 13, 2007 12:51 PM
