rpf1 and federal tire fitment
i have rpf1 18 x 9.5 +15...im thinking about buying federal ss595 255/35/18 tires because theyre affordable and have heard good things about them but ive read they run alot wider...anyone have a pic of what 255/35 federal looks on a rpf1 9.5 or a 9.5 wheel period?
So far, really liking my Fed 595 EVO 265/40/17's (as wide as some 275's)
As noted, the +15 offset w/the 255 which is really a 265 will be next to impossible to fit correctly on the stock body rear
Heres a pic of the 265 on a 9.5"
wow, so what size in the federal 595 would you recommend...which would be the same size as a normal 255/35? 245/35 im guessing? i understand these wont be easy to fit but my fenders are already rolled by the previous owner...i dont mind giving it a little camber if needed...just want it to look good...what other tire is there thats affordable and ok quality if the federals wont work?
Most of us in this section or more Function or Form. Its not the tire size thats making the proposal tough, its the +15.
Ive never seen a proper setup using a +15 on a stock body EVO. Rolling is not going to get you there. This will need a good fender pull, bumper bolt relocate & a 245/35 tire (+15 is a show offset only)
Guys who say they are making it work are putting up w/way out of spec rear camber, rub & an ill handling rear end
We'd rather see you run a more modest offset w/zero rub so you can drive aggressively w/out rub issues
Guys who say they are making it work are putting up w/way of spec rear camber, rub & an ill handling rear end
MinusPrevious (May 4, 2016)
Why not just sell them now and get a wheel that's? You're not trying "something different", it's a setup you can consistently see at car shows with guys that can barely get their car in the parking lot without rubbing and scraping. Too much offset, with too narrow of a tire on too wide of a wheel.
If you got them for such a good deal, flip them for a some profit, and buy a wheel that fits. If you want a 9.5" wheel, that really means a +25 offset at minimum. 35 to 38 offset is ideal to fit a 265/35r18.
Market them for EVO X's, and other platforms they might fit. That's def hard to sell for an 8/9..
detroit pistins
19
Jul 23, 2013 07:25 AM
DepoRacing
13
Jan 22, 2010 11:39 AM
crypto
For Sale - Wheels / Tires / Suspension / Brakes
Dec 27, 2007 10:19 AM
sna08
May 6, 2007 05:03 PM
