Replacing factory springs - help please
Old May 22, 2016 | 02:19 PM
rartist's Avatar
I have a 195k mile 03 VIII with its factory springs. At 155k miles the front struts packed it up, and I was able to get new Bilstein struts installed. Problem is that I've had three sets fail each after a year or less and had them replaced each time. Ive recently had a set put in and things still don't feel right.
Someone suggested to me that my factory springs may be the cause of the short Bilstein life, and things have started to feel overly bouncy. I've looked around and haven't been able to find stock replacement springs, but I do see lots of lowering springs.
My VIII is a daily driver getting lots of miles, and I've never planned on lowering it. Would getting new 1" lowering springs work out for me in the long run, and best cure my strut issues?
Please help
Old May 22, 2016 | 02:35 PM
edsct9a's Avatar
Did yours have Bilsteins stock? To me it sounds like you are using non Bilstein springs on Bilstein struts, am I correct? If so that is probably why you are blowing them so fast. If you don't want to lower them go with some MR springs or some works or swift springs.
Old May 22, 2016 | 02:41 PM
rartist's Avatar
Yes, stock springs, (front) Bilstein struts; so far don't see the Bilstein replacement springs for the VIII
Old May 23, 2016 | 09:39 AM
rartist's Avatar
New left front strut failed on me on the way to work this morning. It would be great if anyone could suggest a spring/strut replacement that I could use to end this nightmare. Thanks.
Old May 23, 2016 | 09:50 AM
edsct9a's Avatar
Find some used MR springs or go with works/swift springs made for the MR as well.
nlp187
Jul 8, 2012 10:32 PM
EvoDan2004
Nov 27, 2007 07:44 AM
MIevo8MR
May 25, 2005 07:11 AM
wprettyboy
Jul 10, 2004 04:32 PM
soundpimp
13
Feb 4, 2004 08:27 PM
Quick Reply: Replacing factory springs - help please
