Evo 4-7 knuckle and brembo brake question
Hi.
Is the knuckles on evo 4-7 the same? And if the brembo brake discs and calipers are the same size ( 320mm front 300 mm rear) and calipers on 5-9? Im thinking of putting on the brembo on a evo 3 and have seen here on this forum thst the evo 4 knuckles fits with a new ball joint. Just unsure on the other knuckles
Evo4-5 are similar.
Evo 6 is different as the balljoint sits in the knuckle rather than the arm.
Evo7 knuckle is different as it has a larger wheel bearing, wider strut mount and the toe link bolts from the bottom.
But the brembo gear is all the same from evo5-9 in terms of calliper, pads and discs.
Brembo kit will fit evo4 knuckles no issues, I had the full set on my evo4 when I had it.
Evo4-5 are similar.
The ball joint has been removed from the arm, turn upside down and now lives in the knuckle like so:
http://www.rosssport.com/imagecache/...92_438x433.jpg
Then bolts into the arm at the end:
http://www.part-box.com/images/MR455346.JPG
MisUnderStood
10
Nov 27, 2017 03:56 PM
ToddRhodes
Jun 27, 2012 05:30 PM
AngryEvo8
Jul 4, 2009 11:36 AM
DaWorstPlaya
Oct 21, 2008 09:47 AM
importrp
Evo 'For Sale' Suspension / Brakes / Handling
Aug 31, 2006 12:56 PM
